A Dreaded Amstrad Sky+ Receiver!!
Discussion in 'Sky Digital TV Forum' started by rasb0, Feb 28, 2005.
  1. rasb0
    rasb0
    Dec 11, 2004
    251
    Bolton
    +4
    A Dreaded Amstrad :eek:
    However, I have hooked it up to my Tosh 46WM48 (RGB scart) and can't see a thing wrong with it. Certainly better than my ntl cable receivers. :clap:
    It's an Amstrad DRX180! Mean anything to anyone? :confused:
    All those who have had problems, were they evident from the start or did they develop over time? What should I be looking out for next? :rolleyes:
  2. Starburst
    Starburst
    Jul 13, 2000
    17,846
    Ilkeston
    +975
    The DRX180 is the model number for their version of SKY+, however there are a number of hardware revisions that are covered by that model number (PACE do the same thing).
    There is/has been a faulty batch or production run which has resulted in the banding issues reported by some (software fix expected), earlier models and I suspect future revisions did not and will not suffer with the same problems.
    Worth remembering that PACE went through exactly the same issues with their "soft focus" problems which affected a batch of their SKY+, it to took quite a while for a software patch to be written, tested and deployed.
