A different approach to amps
Discussion in 'AV Receivers & Amplifiers' started by DDDavo, Jun 11, 2004.
  1. DDDavo
    DDDavo
    Basically, i need for a project to build an amp (well part of it is an amp) the speakers i'm using are 45Watt full range (2 of them) so therefore not needing sub or tweeter. However, i need some form of amp, printed circuit board pre assembled or one i can assemble, it has to be relatively cheap and provide around 40-50watts rms per channel (2 channels needed) supporting stero input too.
    Does anybody have any ideas where i can buy one from pre assembed or get the info from?
    Many Thanks
  2. Londondecca
    Londondecca
    Dec 21, 2003
    2,100
    +103
    What is the rest of the system and how much is your budget.
  3. DDDavo
    DDDavo
