a decent speaker cable for surround and rears please
Discussion in 'Home Cinema Speakers' started by mick23, Jun 6, 2002.
  1. mick23
    mick23
    Mar 20, 2002
    801
    uk
    can someone recomend desent modest price cable for rear speakers please thank you
  2. Lowrider
    Lowrider
    Cable Talk 3.1
  3. Ian J
    Ian J
    Aug 6, 2001
    25,631
    +4,906
    Cabletalk 3.1 is a good speaker cable (which I have used for fronts in the past) but it is quite inflexible.
    I use Ixos 607 for my rears which is flat and slips under the carpet very easily. It is also cheaper than Cabletalk
  4. garmtz
    garmtz
    Mar 27, 2002
    305
    Netherlands
    Oehlbach, IXOS and Nordost all make very flat and good-sounding loudspeaker cables.
  5. stranger
    stranger
    cable talk flat one is good too but if you are on a budget try-wait fo it richer sounds flat cable, i think it's called litz and is in different sizes.
