A/D card suggestion please :)
Maxiqavu
Hi guys,
Im in need of a A/D card to replace our old DT2828 card we are using at the moment.
Im goin to buy about 4 of them, with a budget around 5k AUD. Could you guys suggest for me some of the suitable options so i can check them out, thanks a lot :D This is some specifications for the card DT 2828 that in use up to now:
  • Resolutions: 12 bits (both A/D and D/A)
  • Throughput: A/D 100khz D/A 130 khz
  • max A/d gain: 1
  • Number of A/D channels: 4SE
  • BNC connector of analog input (optional)
Again, thanks a lot for every suggestion :D
P/s: I've been after sth like this http://buy.advantech.com/PCI-1714U/PCI-1714U/model-PCI-1714U-BE.htm but it seems to be over budget and advantech as my boss said didnt match the quality with their expensiv price :)
formbypc
Haven't a clue what to suggest, as I don't see what application such a card would be put to, in terms of Home Audio.
What are you using the existing card(s) for?
