A couple of questions.
Discussion in 'Blu-ray & DVD Players & Recorders' started by zepfan49, Oct 11, 2005.
  1. zepfan49
    zepfan49
    Hello
    I hope someone can answer these questions, I've searched everywhere for someone asking the same.
    1. I have a Freeview box with two scart sockets, one TV OUT, one VCR OUT. Are they both doing the same thing? Can you use the TV out socket to connect to a DVD recorder for instance.
    2. If a freeview RGB signal is sent to a DVD recorder and the recorder is connected to a TV with component connectors, would you be able to view freeview this way?
    Thanks in advance
  2. Phantom Phixer
    Phantom Phixer
    Jul 23, 2005
    127
    1. You would normally connect the Freeview box to the DVD recorder using the TV out connector. The VCR connector will probably not support RGB.
    2. Not sure, but I suspect you would need to have the recorder switched on to do this. The scart sockets will loop through in standby for RGB. You would need to check the manual for the DVD recorder you have.
  3. ROYOLD
    ROYOLD
    Jul 5, 2005
    3,898
    103
    Royton, Oldham. Lancs.
    +296
  4. zepfan49
    zepfan49
    Thanks Phantom & Roy.
    Since I posted the questions I've scoured the Freeview instructions, you are right, the VCR OUT doesn't have the RGB pins connected.
    I am still a little confused as to why it will play throught the component leads though. I have it connected now, FREEVIEW(rgb selected) scart TV OUT - PANASONIC ES10 - TV using component leads from recorder to TV.
    I was under the impression that RGB signal would not travel on Component cables, is the actual signal being changed back to composite before being sent to the TV along the Component cable?
    Sorry for maybe sounding thick but I'm still relatively new to this, I made a silly assumption to start with that the VCR OUT was RGB, doh. No wonder the picture through the recorder was not what I expected, through TV OUT it is really clear, no dot crawl etc.
  5. Phantom Phixer
    Phantom Phixer
    Jul 23, 2005
    127
    I expect the RGB signal is being processed by the recorder and sent out as Component video. Are you still able to watch freeview with the recorder in standby?
  6. zepfan49
    zepfan49
    There was no picture in standby, so your assumption looks correct to me about it converting to component.
    Thanks for the input, appreciate it.
