A Couple of Loewe Questions
Discussion in 'TVs' started by Garrett, May 26, 2003.
  1. Garrett
    Garrett
    Apr 21, 2001
    33,101
    2
    167
    The best thief you’ll never see.
    +4,363
    I set the picture some time ago with a set-up disc but just recently I’m finding the skin tones especially in the studios are looking like that guy David Dixon? Could some one who has use a setup disc let me know their settings.
    Also my number 1 key on the remote need a lot of pressure to work, can this easily be repaired at home, if not will it still come under my extended guarantee.?
  2. groundy
    groundy
    Dec 8, 2001
    1,553
    39
    Northern Ireland
    What a horrid thought :laugh:.
    It would appear that your Colour setting has changed Garrett. Not sure why this would have happened - maybe just reverted to default or something. Anyway, I set all my levels with Avia - which offcourse is optimised for NTSC but I tweaked a little here and there to achieve a good result with PAL material as well. Settings as follows:
    Colour: 36 (anything from 32-36 looks good)
    Contrast: 38
    Brightness: 25 (Aconda default was 23)
    Sharpness: 1 (lowest setting and takes some getting used to)
    Give them a go and see if it helps any. Your default settings on your Aconda might be different to mine and your room lighting conditions will vary but see what you think anyway :).
    Not sure if the remote will be covered under the extended guarantee - is it with Domestic & General? Have a look at the fine print if you have the documentation. It doesn't sound like a major problem though and the area inside/around the Number 1 key might just need cleaned. You can take the Control 150 apart as it's just clipped together. Be careful and prise it apart one side at a time.
  3. Garrett
    Garrett
    Apr 21, 2001
    33,101
    2
    167
    +4,363
    Thanks for the reply groundy:smashin:
    I have been using those settings and been giving them some time to adjust to which I now think is all right, apart from the sharpness. Which I had at 2 before and find 1 takes a lot of detail out of things. So I have gone back to 2 I even think it could stand a bit more.
    Can’t see how to prise the back of the remote.
