A couple of HD-DVD players for you.
Discussion in 'Blu-ray & DVD Players & Recorders' started by mjn, Jun 8, 2004.
  1. mjn
    mjn
    May 24, 2001
    22,721
    Herts, England
    +10,861
    New from HKFlix, the leader in Region Free equipment, are two DVD players
    that are designed for use with HDTVs. If you have an HDTV, you will want
    one of these. Both the Momitsu DVD-V880 and Samsung DVD-HD931 will
    upconvert the 480i DVD standard to 720p or 1080i right at the source,
    enabling a far better picture than if you use an outboard processor, or
    your monitor's built-in interpolator. The Momitsu, priced at only $246.95,
    also has a built-in PAL to NTSC converter, plays MPEG-4/DIVX discs, and is
    VCR-Friendly. HKFlix also offers a full selection of digital video and
    audio cables so you can get your player up and running right out of the
    box.
    Momitsu DVD-V880 ($246.95):
    http://www.hkflix.com/coupons/hkflix_n56/#C
    Samsung DVD-HD931 ($399.95):
  2. buns
    buns
    Apr 29, 2001
    6,100
    58
    Belfast
    havent these been about for a while now? Or are these updated models which have strikingly similar designations?
    I do tend to object to
    ad
  3. mjn
    mjn
    May 24, 2001
    22,721
    Herts, England
    +10,861
    yeah i saw that, i just copied the blurb :)
  4. Lepton
    Lepton
    Mar 26, 2004
    69
    11
    Greece
    AFAIK, the Samsung is NTSC only. The European model is called 935. There were many complaints about its picture quality through DVI. Two models are replacing it in the US, the 841 ang 941, the former already on sale and, according to AVS, with many problems regarding build (Hardware & software). Seems like picture quality is improved, though.
  5. rscott4563
    rscott4563
    Jan 21, 2003
    1,054
    38
    Cumbria
    :laugh: :rotfl: :laugh:
    Makes you laugh what some manufacturers claim about their hardware..
    Firstly non of the dvd players above are HiDef, upscaling SD doesn't make it HD it just makes it upscaled...
    Even funnier, I'd like to see anyone show one of the above dvd players outperform any of the current or previous generation of video processors such as the Lumagens, iScan HD, Crystalio etc...
    Ryan
  6. Lepton
    Lepton
    Mar 26, 2004
    69
    11
    Greece
    True indeed, rscott. I think the Blu-ray players are the only HiDef at the moment, right? Are they available yet or just showcase models?
    I don't whether the Samsung was the first upscaling player, or maybe the first to upscale through DVI, but there are many and certainly much better players out there now.
  7. alancolledge
    alancolledge
    Feb 2, 2004
    518
    Middle England
    +5
    My Yamakawa does upscale too as I'm sure your aware, but I have often considered how many lines of image are stored on the disc.
    one of the previous posts says 480i but even rgb is more than this. Or am I getting confused :confused:
  8. buns
    buns
    Apr 29, 2001
    6,100
    58
    Belfast
    :D you have me a bit confused anyway!
    Your player does upscale. What will be stored on disc will most likely be 480i for NTSC type stuff and 576i for pal..... RGB is just a method of transmitting the info
    ad
  9. alancolledge
    alancolledge
    Feb 2, 2004
    518
    Middle England
    +5
    Ignore me Buns, have checked a few other threads on hi def and upscaling. What I meant in regard to RGB is that when connected this way my Sky + shows 625i lines on my plasma.
    I know I am getting standards confused here :blush:
  10. rscott4563
    rscott4563
    Jan 21, 2003
    1,054
    38
    Cumbria
    As Ad said RGB is only a transport method for the picture.
    Pal is 625 lines total, with ~49 lines not used for picture resolution, this gives a total picture resolution of 576i/p. So Pal can be described as 625 or 576.
    Ryan
  11. cybersoga
    cybersoga
    Apr 7, 2002
    1,630
    48
    UK
    +25
    How much do they charge to ship to england? Customs charges? Are there any UK dealers of the Momitsu DVD-V880?
