a constant sshhhhhh noise from rear speakers
Discussion in 'Home Cinema Speakers' started by mkendall, Sep 24, 2001.
  1. mkendall
    mkendall
    I.ve just bought some new gale rear speakers wired them up all correctly but when playing sound through them in the background i can hear a constant sshhhh noise anybody any idea are speakers faulty thanks
  2. Ian J
    Ian J
    Aug 6, 2001
    25,631
    +4,906
    Test them by using them as the front stereo pair. If they are faulty the noise will remain. If it has gone away you will have to look elsewhere for the problem.
