a budget home cinema needed
Discussion in 'AV Receivers & Amplifiers' started by mkendall, Sep 4, 2001.
  1. mkendall
    mkendall
    i would like to progress from my pro logic tv to home cinema.Could someone recommend a mp/receiver dvd and speakers. ive changed my mind from a cinema package to separates but so much kit out there. about £500.00 to spend.unless i buy some kit now and spend more later.
    Thanks <img src="smile.gif" border="0">
  2. hobbes
    hobbes
    £500? That's pretty tight. But here's an option.
    Toshiba 210E<br />Marantz SR-4200<br />Wharfedale Diamond 8.1 Front Speakers
    You could get that for now (totals about £500ish) then add some rears at a later date.
    But thats just one option.
  3. AMc
    AMc
    Nov 20, 2000
    7,012
    Near Norwich
    +3,643
    You could try sdb-electronics for a <a href="http://www.sdb-electronics.com/Yamaha_AVAR.htm" target="_blank">Yamaha A5 for £199</a><br />and QED for <a href="http://www.qed-uk.com/cgi-bin/q?i=Kqhw334PfBX0&bg=216&bp=stargates&v=10" target="_blank">Eltax Stargate X1</a> (sub/sat if space is tight) or <a href="http://www.qed-uk.com/cgi-bin/q?i=Kqhw334PfBX0&bg=216&bp=silverados&v=10" target="_blank">Eltax Silverados</a> if you want bigger boxes (both are £109 delivered!)<br />That will leave you £192 to find a decent multiregion DVD and some interconnects. No idea about what is a good value DVD player at the moment.
    I have the Yamaha Amp (but I haven't used this supplier) I also have just got the Eltax Stargate X1 from QED (great service) and I'm pleased with the speakers too. I got the Stargates to replace some Mission speakers because my new front room couldn't accomodate them and for the money they're great.
    I know this isn't an audiophile system but there's a lot of bang per buck.
    AMc
    [ 04-09-2001: Message edited by: AMc ]</p>
  4. Zacha
    Zacha
    If the Denon 1602 is on its way (or just out) in the UK, you could probably get an excellent deal on the 1601.
