A Bit of Help Please...
Discussion in 'Home Cinema Speakers' started by columbo81, Feb 10, 2009.
  1. columbo81
    columbo81
    Oct 10, 2008
    36
    ok, at the moment I've got this all-in-one system. Now I'm looking to upgrade as funds allow and I'm thinking of buying this while it's cheap. Would my system be able to drive this this? If it can, can anyone recommend some cheap bookshelfs that I can use for fronts just now (They'll be getting used as rears when I move out and I'll get floorstanders for the front). The amp and sub will be changed when I can.
  2. columbo81
    columbo81
    Oct 10, 2008
    36
    Anyone?
  3. Stoatman
    Stoatman
    Jan 26, 2005
    1,023
    +88
    I dont see a problem with changing speakers but if I were you I would replace all three at the same time with the 1010 speakers also for the front. Also make sure there are "normal" speaker connections coming from your amp ie spring clips or banana plugs. Also the system will probably have a built in crossover around 140 hz as thats where the small speakers are rated to. The Q acoustics would be ok but can go lower.
    Q ACOUSTICS 1010i SPEAKERS (PAIR) - available from Superfi UK Visit http://www.superfi.co.uk/index.cfm/page/moreinfo.cfm/product_id/3693 for details
