A bit of a rethink ...
Discussion in 'Plasma TVs' started by *ChrisB*, Apr 24, 2005.
  1. *ChrisB*
    *ChrisB*
    Apr 22, 2005
    310
    Berkshire
    +11
    Thanks to the help some of you guys have given me this weekend (& thanks to HD for answering my rambling pm's :lesson: ) and after alot of research here on the forum I've decided it will be sensible to update my Arcam AV50 Amp & Pan Rv60 dvd so to get the best from the new plasma.
    I thought I'd just run it by you before hammering the credit card .....
    Pan Pw7 + component board
    Yamaha DSP-AX750SE
    Pioneer 575a DVD player
    I think I'll probably run my Sky/TiVo via composite out using the component upconversion for now until I change over to Sky+
    I'd appreciate your comments :)
    Chris
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,299
    +1,215
    geta JS RGB>YUV box can be found seconhand£100 is or the JS RGB>VGA for Tivo (i'm sure this does RGB) and Sky Teressa has these so ask her advice on settings etc
  3. phillfyspoon
    phillfyspoon
    Oct 21, 2003
    2,128
    Hampshire
    +76
    the new yamaha model is out the 757 try and find that is same price.
