gordyjackson
Hi Guys (and gals I'm sure!)
I have had a reasonable setup for a few years, an old VGA Sony projector sat on a cupboard at the back of the room and a manual sapphire 1.8m screen in the opposite corner. My speakers all in the right places etc etc. This Xmas I decided to upgrade to a Benq W1070 and plopped it does where the old one sat and the image is huge! I can'r shrink it down to fit in my screen either so I'm a bit stuck, either:
A. A Bigger Screen and move all the speakers
B. Mount the projector on the ceiling half way down the room
C. Return the projector and is there one that has a more variable 'zoom' function?
I am still within my 14 days so could return it and swap for something else depending on anyones advice here?
What do you think?
Cheers in advance
GJ
By The way, my room is 4.4m long by 2.8m wide if that helps. I would like to go from corner to corner
What do you think?
Cheers in advance
GJ
