A balancing act
Discussion in 'Home Cinema Speakers' started by dave48, May 21, 2002.
  1. dave48
    dave48
    Mar 9, 2002
    271
    Germany
    +3
    Just about to finally go out and buy a centre speaker when I suddenly started thinking - how on Earth am I going to balance this thing on top of my tele without it falling off? The flat bit at the top of the tele is about 10 - 15cm deep, the centre speakers I'm looking at are something like 45cm deep. According to the manual they should be placed flush with the front of the TV screen.
    Has anyone found / come up with a solution to this problem? The speaker really needs to sit on top of the tele, but I don't want it to fall off next (if there is a next time) I decide to vacuum the place.
    Dave48
  2. eddiea
    eddiea
    I have a Monitor Audio Gold Ref on my tely, front edge level with screen, speaker pointing down a few degrees, held on with Blue Tak.
    regards
    Eddie:cool:
