A/A formats????
Discussion in 'AV Receivers & Amplifiers' started by PEZ, Jan 9, 2004.
  1. PEZ
    PEZ
    Similar to the previous thread but.....
    Can you only get DTS and NEO 6 etc... only if you have all the speakers set to on on the receiver? I don't have six speakers so will it cause a problem?
    cheers:smashin:
  2. gandley
    gandley
    Aug 31, 2003
    5,102
    Paradise Lost
    +269
    yep all speakers need conecting form a 6.1 sound format
    DTS however is 5.1 and so is neo so these work with the 5 speaker set up.
    you wont get dts-es or true thx-ex
