jamez2010
i have put a stud wall up using MDF (9mm) and I am planning to put my tv up on it, do you think this will be strong enough, and also it has come with some self tapping screws (6off) they will be 5cm long, which goes through my wall and out the other side (not a happy wife) so i was planning to get some shorter ones but put more in does anyone think this will be ok? never wall mounted a tv, but with a puppy on the way felt it was a good idea.
thanks in advance
thanks in advance
