9Gb DVD-RAM
J
Jonny1973
I'm considering getting a DVD recorder to go along with my Sky+,
I see that Panasonic now do a 9Gb DVD-RAM disk, do you have to physically turn the disk over or is it like a dual layer disk????
D
DucatiEVO
I've got a few 9.4Gb discs, but my system (hs2) just treats them as 2x4Gb ones in a single case, and yes you have to turn them over.
Bit of a bummer as I assumed you could record a movie longer than 2 hours on one, but you can't without splitting the movie up into 4gb parts!
J
Jonny1973
Damn, I hate flippers!!!!
I might wait until dual layer recorders appear then.
nwgarratt
Just get a Hard Disk model otherwise you will have a very long wait for a dual layer recorder.
My Panasonic HS2 can do 8 - 52 hours (40GB). The E100 (80GB) doubles that and the coming soon E95 (160GB)will make it four times more capacity than the HS2.
You won't need much RAM after that.
J
Jonny1973
Sony are about to launch a dual-layer writer for a PC which uses Verbatim dual-layer dvd-r.
Consumer DVD recorders should follow.
nwgarratt
Actually it uses Dual Layer +R (2.4x) ;)
As well as burners from Ricoh (+R), Pioneer (-R) etc.
However, I bet TV Dual Layer DVD recorders will be at least a year away and then they will be ridicolously expensive for another year or so.
