9986 so good I know need a new DVD Player
Discussion in 'LCD & LED LCD TVs Forum' started by craigsomers, Feb 6, 2005.
Tags:
  1. craigsomers
    craigsomers
    I am so pleased with my new 32pf9986 , I have decided I need a new DVD Player. I have a few questions though. I don't want to spend alot £50 ish if I can and have heard the progressive scan players are the new ones to go for, can anyone advise a cheap player and advice , also how do I plug the progressive scan player into the TV. Many Thanks Again
    Craig
  2. jimsan
    jimsan
    Oct 8, 2004
    1,610
    41
    Dumfries, SW Scotland.
    +9
    Craig,
    Have you got a Tesco near you? They're selling Toshiba 240's for £49! This is a fantastic Progressive Scan DVD player which will work perfectly with the 9986. Go get it and order a Component lead from tvcables and we'll tell you how to hook it up when you get it.
    http://www.tvcables.co.uk/cgi-bin/tvcables/CP001.html
    Jimmy
  3. ivanch
    ivanch
    Feb 6, 2005
    15
    3
    Has anyone tried the Pioneer 575 with the 9986?
    Any flicker problems?
    Ivan
  4. craigsomers
    craigsomers
    Thanks Jimsan
    I have got myself a 240e , and some decent component leads from richer sounds. What Next, I think I know what to do (i.e use the vga converter and the component to vga adapter both supplied with tv. My confusion is how do I pass the audio to the tv. Dont' have an AV amp so need to use the tv for sound.
    Craig
  5. jimsan
    jimsan
    Oct 8, 2004
    1,610
    41
    +9
    You'll need a Phono lead. This'll connect to the appropriate Audio outs on the DVD player and the Audio IN on the TV. Make sure you connect to the correct ones.
    Let us know if you're struggling. Hook up a scart too. Actually the scart may provide the audio anyway...even when using the Component feed.
    Let us know...
    Jimmy
  6. craigsomers
    craigsomers
    If I connect scart will the audio only work when on that particular Av channel. and Not when on the DVI Input?. Also where are the audio in ports for the DVI Channel?
    Craig
  7. andy c!
    andy c!
    Jan 18, 2005
    65
    HI,
    the DVI lead is picture only. Connect two phonos to the audio outputs on the 240, and then on the two phono inputs next to the dvi on the philips...
    andy c!
  8. craigsomers
    craigsomers
    Sorted, Sorry for being Dim, but wanted to make sure.
    Thanks All
    Cheers Craig
