9986 Adaptor lead??
Discussion in 'LCD & LED LCD TVs Forum' started by rnsdm001, Mar 4, 2005.
Tags:
  1. rnsdm001
    rnsdm001
    I have been instructed that I should have with my Philips 32pf9986 a lead (see below)....... I do not have this with my set - do I just request one? Or is it not that important?
    In the box you should find an adapter with a lead. This'll have either Red/Yellow/White ends or, with later versions, Red/Green/Blue ends. This adapter allows you to connect Progressive Scan DVD players which provide fantastic Picture Quality (PQ). If you want to connect with this you'll need a Component Lead
  2. jimsan
    jimsan
    Oct 8, 2004
    1,610
    41
    Dumfries, SW Scotland.
    +9
    If you have a v1.3 then no lead is included. All the rest should have the lead and you should persue your supplier for one.
    Jimmy
