9800pro Flashes when using s-video
Discussion in 'Desktop & Laptop Computers Forum' started by GazH, Aug 15, 2005.
  1. GazH
    GazH
    Apr 17, 2004
    427
    On the corner of Wabash and Lake
    +75
    Hi All,
    I've got a Sapphire 9800pro which (basically) works really well with my Media Centre PC.
    For some reason, when I connect it to my TV using the s-video connector, it flashes.... Black and white then back to normal colour... constantly. Whether I'n media centre or plain XP.
    It works fine when I plug in the s-video to composite converter and also works fine through VGA output to PC monitor.
    Its connected to a sony 28" CRT widescreen TV.
    At first I thought it may be the refresh rate, but changing this (even to an interlaced rate) didn't make a difference.
    I've got Catalyst 5.4 driver installed.
    Any Ideas ??????
    Gaz
  2. richjthorpe
    richjthorpe
    Aug 2, 2004
    2,029
    41
    dat london
    Have you set the input on your TV to be S-Video ? On TVs a Scart socket or bundle of connections can be set to different inputs. For example, on my Sharp TV, I can set input 4 to be Composite, S-Video or Component on the bundle and Input 2 can be Composite or S-Video through a Scart.
    Richie.
  3. GazH
    GazH
    Apr 17, 2004
    427
    +75
    Thanks for the reply Richie.
    My TV automatically detects s-video through scart so you can't change it in the menu options.
    I have also tried it using my AV4 input which is s-video (using s-video -> s-video cable) and it is still the same.
    I may need newer driver, but the ones I've got don't cause any problems with XP or MCE2005.... except through s-video of course :D
    Thanks again Richie
    Gaz
