9800 pro upgrade
Discussion in 'Desktop & Laptop Computers Forum' started by Ethan2000, Mar 13, 2006.
  1. Ethan2000
    Ethan2000
    Jan 20, 2006
    945
    Hereford
    +65
    First off the specs: (AGP MOBO)
    AMD XP 2600+
    1 gig of value ram
    HIS Excalibur 9800 pro platinum (oc'd a little bit)
    120 gb HD
    windows XP
    350 psu
    Ok the question is I have the above card at the moment and I play mostly counter strike source.(I get about 79 fps in the stress test and about 40 ish in game) I have just read that there is a nvidia 6800gs on AGP and I can get one for about £130 ish. Now I know I need a new PC but would rather wait till nearer the end of the year, so is it worth the upgrade as the cpu is a bit of a bottleneck now ? thanks for any help and advice. Cheers
  2. Cable Monkey
    Cable Monkey
    Feb 10, 2002
    3,494
    Birmingham
    +205
    The 6800GT is a considerably better card more naturally aligned with the x800 series cards. However Source coding is kind on ATI cards and an AGP card bought now for £130 will lose a lot if resold second hand later. I would save your cash and put it towards the best you can afford later.
  3. HMHB
    HMHB
    Nov 11, 2001
    27,408
    Nottinghamshire
    +6,287
    There's also the 7800GS AGP card now, but that will set you back nearer £200 :eek: Having said that, I'm considering getting one :D
  4. Ethan2000
    Ethan2000
    Jan 20, 2006
    945
    Hereford
    +65
    yeah iv'e just been reading up on it in this months custom pc they tested it in a AMD 2500+ pc (and i have the 2600+) so it was a nice review for me. I must admit im leaning towards the 7800 now as that upgrade should make the pc see another year at best. cheers for your help gents.
