richard plumb
Can you get 96" screens, or is everything pretty much 92" or 106"? I've given up on my fixed screen idea (not portable) so going to keep it simple with a manual screen where my old one used to be in the ceiling void.
Problem is, from the distance I have my benq w1070 installed, to the screen is about 3.13m. The smallest the projector will go is 95" diagonal. So a 92" screen would be too small. I think a 106" would be too big for the room (we're sitting about 10ft back), plus the slot in the ceiling is only 220cm wide and I don't want to be fiddling with that. So I was wondering if anyone makes a 96" or thereabouts? Or anyone that will make a custom size that isn't too expensive (sub £300)
If I got a 92" screen, would the overspill be acceptable do you think? Would be about 1.5" in each corner, so maybe just over an inch border all round? That should be able to be kept within the black border??
