96/24 output from DVD players?
Discussion in 'Blu-ray & DVD Players & Recorders' started by Kane D Williams, Feb 21, 2002.
  1. Kane D Williams
    Kane D Williams
    Jan 24, 2002
    750
    Nr London
    +11
    Hi there
    As Denon are including DVD-A decoding and DTS 24/96 decoding as part of the AVC A1SE upgrade, does this mean that players will soon have digital outputs to allow the 24/96 signal to be taken to the amp's decoders? I reckon so, but what about the copy protection issues that have been plaguing this for ages?
    Cheers Kane
  2. Jase
    Jase
    Mar 16, 2001
    10,804
    United Kingdom
    +2,693
    Some players (Pioneer) can already pass a 24/96 signal via the digital outputs. Some cds & the Seven dvd have a 24/96 two channel track on them.
    Most others downconvert the signal though.
    Denon have done their own thing with regards to DVD-Audio and bass management etc (Denon Link).
    Not sure about the Copyright side of things though.
  3. gavan
    gavan
    Dec 20, 2001
    3,984
    Rapture
    +287
    Some players will already do this through the existing optical/coax TOSlink. I don't think a new format is needed.
    Also of course, the amp must be able to accept the signal too.
    eg. My Sony DVD can play 96/24 sources over the toslink and through the Sony 930 amp.
    Gav
