[9509] setting the clock?!?!?
Discussion in 'General TV Discussions Forum' started by vivaatloni, Jul 15, 2004.
  1. vivaatloni
    vivaatloni
    I have a wierd problem: Wenn I push the clock on the RC the time is wrong. About 20 to 30 minutes earlier than the right time (wich is on teletext). I can't set the time anywhere in teh menu & service menu.
    Are you also experiencing this??
  2. Digiman
    Digiman
    Dec 17, 2003
    367
    +17
    Are you watching a channel with teletext when you press the clock button?
  3. vivaatloni
    vivaatloni
    Yes I appears with every channel. The time stays behind the teletekst time and it is very annoying.
  4. Digiman
    Digiman
    Dec 17, 2003
    367
    +17
    When you say 20-30 minutes do you mean the clock is also running fast then slow or is it an exact number of minutes?
  5. vivaatloni
    vivaatloni
    I think fast then slow, but haven't really tested.
