930 to 3801 upgrade ?
Discussion in 'AV Receivers & Amplifiers' started by xtremecool, Feb 3, 2003.
  1. xtremecool
    xtremecool
    Dec 9, 2002
    25
    3
    Cheltenham
    I am thinking of upgrading my Sony 930 amp to something a bit newer and a lot less hiss :(
    After reading around the web it seems that there is little difference between the 3802 and the 3801 (can anyone who has had or heard both confirm this?) and due to this I am thinking of looking around for a SH 3801 to replace the Sony.
    The question is do you think it is worth upgrading from the 930 to a 3801?
    I use the system about 50/50 music and films with the speakers being B&W 603s up front, LCR60 centre & 600s at rear?
    Jon
  2. G1OSE
    G1OSE
    Jan 22, 2003
    292
    london
    hi mate i think the only difference is ther prologic to prologic 2 but im not sure someone else will inform you more on that
    i was just wondering what you recon on your b&w set up as im lookin to get a similar one maybe with the 601's for the rear but are you happy do you have a sub or does it sound ok without one?
  3. Demon
    Demon
    Dec 13, 2000
    956
    Cheltenham
    +57
    G1OSE
    For true Home CInema, you really need a subwoofer, this is for two reason..
    1. The LFE channel goes down well below the 40Hz cutoff of the DM603, so you will be missing out a a sizeable chunk of bass in explosions etc...
    2. If all the other speakers are 'small' i.e. DM601/LCR60, then the bass is redirected to a sub, or your fronts, which is fine for low volumes, but as you turn it up, the fronts will start to distort due to the bass overloading...
    Although I think with this particular setup, you can manage for quite a while without the sub, even @ 40 Hz, the DM603's can produce some stunning low end stuff... but adding a sub does add a new dimension, even to these.
    If you are going to get a sub at some point, then the 600's are excellent as rears, although the 601's are better, the 600's are smaller, and don't look out of place if you wall mount them.... plus if you get a sub, then no doubt any rear speakers will be set to small, and for most, this will mean a minimum of an 80Hz crossover, which suits the 600's fine. This also gives £100 towards the sub!!!
    Both me and Jon (xtremecool) have the same 603/LCR60/600 setup and both of use have bought subs eventually... I was happy before the sub, but you soon realise there is far more depth to films/music then before....
    Mind you, there have been times, listening to music, that I thought the sub was doing a good job, til I realised it was unplugged... so the 603's can suprise at times...
  4. xtremecool
    xtremecool
    Dec 9, 2002
    25
    3
    Cheltenham
    As Phil has said they don't sound bad without a sub you can feel most of the atmosphere of the films, I lived without a sub for 2 years and didn't really think I was missing anything.
    But after getting my sub I have since found that there is extra low bass content in most of my music and films that I had been missing.
    I went with the approach of getting the best I could afford at the time (603s2s & LCR60) and build on it (sub & 600s later), rather than compromising on a more complete setup (more speakers, less quality) and having to upgrade the speakers later on.
    I finally I have a system I am happy with, only thing is I am having to use a lot of will power to stop myself from upgrading the amp now. :)
    Jon
  5. jspone
    jspone
    Dec 5, 2000
    89
    Lancs
    Jon,
    I upgraded from a 930 to a 3802. I think I'm correct in saying the only real difference is DPL II, but this is well worth having this feature if you can get a 3802 within your budget.
    I'm using B&W CM spearkers for the front 3 and a cheap old pair of Cellestions at the back. There is a significant improvement in sound over the old 930.
    Like a lot of people, I added the subwoofer last and I've got to say it's an absolute must. I made the misstake of getting a cheap (200 quid) sub, but it was rubbish. I've now got a M&K and it's the mutts nuts. My advise; get a sub and don't go too cheap.
    John
