9200T Daylight saving bug like 8000T
Discussion in 'Digital TV & Video Players & Recorders' started by Damon, Oct 30, 2005.
Tags:
  1. Damon
    Damon
    Oct 5, 2005
    266
    Croydon
    +4
    Seems that the 9200T has the same error the 8000T had in that the start times for scheduled programmes that are set prior to daylight savings but start after are pushed back an hour when the clock was put back an hour. :mad:
    i.e Egypt on BBC one programmed to start at 21:00 Sunday when I set it on Friday but as the clock was automatically adjusted for daylight savings by going back an hour Sunday morning it changed the start time to 22:00 as though it was assuming the time on the clock was wrong and it corrected the start time to allow for it, rather than it realising that the clock had changed for daylight savings and that the start time should stay the same.
    Seems to be a basic bug that I think they fixed in the 8000T did they not?
    Damon
  2. kbfern
    kbfern
    Aug 17, 2002
    17,955
    Wolverhampton
    +6,131
    I have an 8000 & 9200 and both failed to update the time yesterday.
  3. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,833
    Somewhere in South Yorkshire
    +6,469
    Not the fault of the boxes. The transmitted time remained incorrect for most of yesterday.
  4. Damon
    Damon
    Oct 5, 2005
    266
    Croydon
    +4
    My problem wasn't the time not being updated because it was, my problem was that an hour delay had been added to all my scheduled recordings.
    Damon
  5. therockett
    therockett
    Oct 31, 2005
    9
    I set three recordings on Friday for Sunday afternoon. Got back last night and my box had the British Summer time still on the display, however it had recorded two of the three programmes correctly (still to watch the third)
  6. AlanDL
    AlanDL
    It is not the machine's fault: happened on my VCR and DVDR; I checked teletext and the BBC had not adjusted the time (whereas ITV had). As the machines take the time from the teletext, they are not at fault. I rang BBC along with many others. They have subsequently apologised: said it was a technical fault. The time was corrected around about 5.00ish in the afternoon.
