910 poi
twiglet
am thinking of getting the 910, just wondered if there was SCHOOLS in POI, i work in schools all round the area, and this is a need of mine, my mate has the one and it doesnt have them on his(can he down load them).please help cheers twiglet:thumbsup:
twiglet
Oh nearly forgot where is the cheapest place to get.have found it on Pcworld web site for £430..........
twiglet
Come on all u 910 owners help me out.can u get school list on the poi!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! abd where is the cheaspest place to get one
martmiller
There is no "Schools" POI category on my TT910.
But looking at the interface, you can add your own categories and then you can add your own POIs into those categories.
PocketGPS do it by loading tomtom format OV2 files on to the device, so you should be able to do it if you know the format and the co-ordinates of the schools.
Personally I think it would be a hell of a lot easier to use the schools post code - just a thought :)
