90 degree coaxial connector.????????
A
andycarmi
I have just installed an lcd tv in the kitchen, and connected it to the sky box in the other room using coax cable and a magic eye.
The problem is aerial connection on the tv is at the bottom so have had to bend the cable a far way to get it to go up the back of the tv. Does anyone now if you can buy a coax plug that is at 90 degrees??? the only ones i can find are the F type screw connection.
Andy :lease:
A
akagotenks
so is the main prob that the magic eye connection wont fit? if so what you have to do is just make yourself up a lead coming out of the magic eye an then connect to the tv but if u cant get a coax plug on it you havent got much hope cause you cant get a 90 degree connection sorry mate
Bearded_Malc
Yes, you can get 90 deg coax plugs. I had some from CPC but they weren't very good quality, cheap though, although as CPC charge postage on small orders doesn't help you much.
A
andycarmi
Cheers for the replys thats jst what i need will be ring them up tomorrow to order 1
cheers again :thumbsup:
