9 volt connection
Discussion in 'Satellite TV, Sky TV & FreeSat' started by LISDAR, Mar 14, 2006.
  1. LISDAR
    LISDAR
    Mar 14, 2006
    7
    want to use and change channels with two magic eyes but when i split the 9 volt the magic eye does not work any help
    regards
    Mike:lease:
  2. martynljones
    martynljones
    Jan 4, 2006
    40
    South Wales
    Try the search button, theres loads about this on the forum
  3. JayCee
    JayCee
    Jan 20, 2004
    23,764
    Lanarkshire
    +2,572
    How did you split it?
  4. vex
    vex
    Mar 8, 2005
    2,905
    103
    London, Home Counties & North West
    +261
    Agree with JC
    How are you splitting it,
    Three possible problems, Splitter is not power passing (led on eye does not come on), Faceplate is not power passing (led still doesnt come on) or the splitter can not pass the IR frequencies.
    HTH.
    Chris
  5. antfish77
    antfish77
    Aug 17, 2005
    154
    +4
    hi, I have exactly the same setup. Sky+ in lounge connected via scart, rf out to loft into a Y splitter and then fed down to bedroom and kitchen. We found that you had to have a magic eye in both the kitchen and the bedroom to balance the 9v or it wouldn't work.
    Could it be that one of the magic eyes you are using is dodgy?
  6. LISDAR
    LISDAR
    Mar 14, 2006
    7
    thanks for the advice splitter is not powered just ordinary two way splitter
    tried the balance out using the two magic eyes but still no joy read about a fourway booster will that work
    regards
    mike
  7. JayCee
    JayCee
    Jan 20, 2004
    23,764
    Lanarkshire
    +2,572
    If it's a plastic "Y" splitter that's probably the problem.
    Some are "Isolated"...they usually have a DC blocking capacitor which allows the RF signal through but stops the 9v DC from getting through.
    If you do go for a 4w booster make sure it has "Digital Bypass" in its specs.
  8. AJBSWFC
    AJBSWFC
    Nov 1, 2005
    19
  9. antfish77
    antfish77
    Aug 17, 2005
    154
    +4
    I am just using a standard "Y" splitter on my system, it works fine. Grand cost of less than £1.
    Silly question but, have you switched the RF power outlet on from the menu on the sky box?
  10. LISDAR
    LISDAR
    Mar 14, 2006
    7
    I had the second magic eye connected to a further TV making two TV sets on this line which upset the balance
    but disconnected this and you were right
    ordinary y splitter when connected to two magic eyes balance the supply and all works
    I am very grateful to all that replied and wish that all sites were as good as this one
    Kind regards
    Mike:clap: :thumbsup:
  11. antfish77
    antfish77
    Aug 17, 2005
    154
    +4
    Excellent. I thought it was odd you were having these problems. I also had these problem when initially messing about with magic eyes. Its a reasurringly simply solution in the end!
    Happy viewing.
