9 RGB inputs how?
Discussion in 'Cables & Switches' started by chipsgravy, Aug 28, 2004.
  1. chipsgravy
    chipsgravy
    Aug 28, 2004
    4
    Hello,
    I have 9 RGB scart inputs that I would like to connect to my TV at the same time. Obviously my TV only has 1 RGB enabled Scart socket. What is the best way to go about doing this. I have searched for a 9 way splitter box but have come to the conclusion that it doesn't exist. Any ideas?
  2. Ian J
    Ian J
    Aug 6, 2001
    25,528
    +4,906
    If you cannot daisychain some of these devices together I would suggest that one solution would be several splitter boxes but I wonder if there is anything available for commercial use in shops that would suffice.
  3. bobbypunk
    bobbypunk
    vivanco do a model called 94se which gives 3 rgb scart in to 1 rgb scart out
    they sell for £20 and so buy 4, 3 switchers into 1 of the switchers into scart on TV allowing any of the nine items to be selected with just two button pushes! (£80)
  4. mjn
    mjn
    May 24, 2001
    18,393
    Herts, England
    +5,477
    i have to ask....what are the 9 RGB devices?
