9.4GB DVD RAM disks ?
Discussion in 'Blu-ray & DVD Players & Recorders' started by RecordablDVDfan, Dec 19, 2003.
  1. RecordablDVDfan
    RecordablDVDfan
    Aug 13, 2003
    2,902
    68
    +49
    Are the ones in caddys removable so I can play etc in my LG4040B ? I guess not ? Does it matter what make, can any damage occur to the recorder ?
    I've seen Panasonic double suded caddyless ones going for £9.75 buy it now on ebay, is this a good price ?
  2. bobones
    bobones
    Jan 15, 2002
    453
    +7
    Type 4 (9.4GB) and Type 2 (4.7GB) are removable. I bought a 5 pack of the MediR ones from www.lynxdv.co.uk for about £6 each. They work perfectly and are type 4 discs. www.bigpockets.co.uk sell Ridata RAM in caddies, and www.blankdiskshop.co.uk sell Datasafe ones, but I have tried neither.
    Double-sided discs without caddies at £9.75 is not a good buy. That's the typical price for a Panasonic branded disc in a caddy. Double sided discs outside of a caddy will be very easy to damage since there is no protective layer. You'd be better of sticking to caddyless single sided discs.
  3. keylion
    keylion
    Oct 13, 2002
    212
    Lancashire
    +9
    The doule sided datasafe ones from blankdiscshop are excellent. They are £5.89 each and work just as well as the Panasonic.
    They even look a little better as they come in a smoked dark grey caddy rather than the orange of the Panasonic ones.
    KL
  4. RecordablDVDfan
    RecordablDVDfan
    Aug 13, 2003
    2,902
    68
    +49
    Thanks for info. The disks can be removed from the caddy I take it ?
  5. CARLOS
    CARLOS
    Feb 11, 2001
    6,457
    WEST MIDLANDS
    +1,412
    Yes, Just break out the little red lug and the end opens :)
  6. RecordablDVDfan
    RecordablDVDfan
    Aug 13, 2003
    2,902
    68
    +49
    I don't see any red lug on mine. The disk is a black datasafe disk.
    Perhaps you can't open with certain caddys ?
  7. krismcewan
    krismcewan
    Feb 6, 2004
    70
    11
    Edinburgh
    I got a few of the Ridata Ram from big pockets. They have a small problem that the Panny doesnt like them sometimes and fails to read them. i found that leaving the discs in the machine is the problem.
    Take the discs out and put in another disc and play it for about 5 mins then replace the disc it works fine.
    Personally id buy the Panny Double sided Cart discs next time.
    Chris
  8. BigRD
    BigRD
    Jul 4, 2003
    393
    far far away
    +14
    Too much farting about for my liking. I bought 5 caddyless Panny discs for £20 inc P&P. Fair price for quality discs.
    krismcewan,
    Were you in the Railway last night?
  9. krismcewan
    krismcewan
    Feb 6, 2004
    70
    11
    Edinburgh
    nope i wasnt.
    You fancy a pint this weekend?
    Anyway i wanted the caddy discs as the little fingers may ruin them otherwise
  10. krismcewan
    krismcewan
    Feb 6, 2004
    70
    11
    Edinburgh
    Saing that if the ridata disks fail any more i will just get the panny double sided and put hem in the ridata carts.
    Anyone seen where to get type4 panny disks
  11. Sekal Boy
    Sekal Boy
    Good man, i sell these machines and the panny discs, without a doubt the panny discs are 100% they have never failed on me.
    The r discs are around £2.30 and the caddy less ram discs are £3.90, soon all discs will be caddyless again bringing the price down. In short ONLY USE THE PANASONIC DISCS.
  12. sparkydoo
    sparkydoo
    Does anyone know of a good supplier to buy some panasonic dvd ram media discs from please?
    thanks
    sparkymarky@safe-mail.net
  13. Floob
    Floob
    Sep 1, 2003
    364
    +22
  14. marky_h
    marky_h
    Dec 19, 2002
    369
    Hampshire, UK
    +22
    I get mine (single sided) from 7dayshop - good value. Panasonic shops have them for about £18 for 5 as well.
    Mark
  15. krismcewan
    krismcewan
    Feb 6, 2004
    70
    11
    Edinburgh
    I went and bought the panny disks,
    Chucked the ridata ones out and kept the carts to prevent the weeone gettign her sticky fingers on them.
    Chris
