KILLER NADS
Hi Guys,
I wanted to find out if a 9.1.4 configuration is possible? If so what do i require?
I was originally going to go for 7.1.4 in my room which i am re-doing, but realised that i have plenty of space at the front wides to accommodate 2 B&W spare bookshelf speakers that i won't be using for the Back surrounds anymore.
So i had a thought of why not just use them instead of keeping them in the storage and setup a 9.1.4 configuration instead?
For the AV receiver that i was initially going to go for in the 7.1.4 setup was either the 9 channel Arcam with power amp or Anthem 11 channel AVR.
However is there anything i can buy instead (probably would have to be a mixture of an AVR and power amp) that would make 9.1.4 configuration work in my room?
Thanks.
Thanks.
