8mm Video Adapter
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by jidder, Sep 22, 2004.
  1. jidder
    jidder
    Nov 10, 2003
    bedfordshire
    Hi there,
    Ive got a bundle of old 8mm video tapes I would like to convert.
    Unfortunately the 8mm camera is broken and will not play back.
    Is there any 8mm adapters cassettes available so i can put straight into the VHS video player and convert over.
    Many thanks in anticipation :lease:
    Lee
  2. Kevo
    Kevo
    Aug 23, 2001
    5,425
    Manchester
    +158
    Such a thing doesn't exist.
    Your best bet is to get your camcorder fixed or buy a second hand one.
  3. MarkE19
    MarkE19
    Aug 10, 2002
    17,484
    Rainham Essex
    +2,487
    You are getting confused with the old and very bad VHSC camcorders. The tapes could be put into an expanding case that was the size of the VHS tapes you put in a standard VHS VCR. 8mm tapes are totally the wrong size and incompatable with a VCR so as Kevo said the converter does not exist.
    Mark.
