8mm transfer to mini dv ???
D
dee416
can u tell me if this is possible as i have both camcorders an it would allow me to get rid of my old 8mm which i only use as a player for my old tapes, and what i would require for this job.
MarkE19
If your DV camcorder has it's inputs enabled (most don't:mad: ) then you just need a 3phono to 3phono lead, put DV camcorder into VCR record mode and play back the 8mm tape on the other. Job done:)
If your DV camcorder does not have its inputs enabled, and as I say most don't, then you will need to get a widget enabler (if still available as they could be about to be banned:mad: by camcorder manufacturers).
Good luck
Mark.
D
dee416
where can i source a (widget enabler)as i havent a clue what this is but i gather i need this to activate my phono inputes.
MarkE19
Podcast: Best Home Cinema Sources and B&W 805 D4 Speaker Review and more...
