890 skip back
Discussion in 'Blu-ray & DVD Players & Recorders' started by Ged, Feb 18, 2003.
  1. Ged
    Ged
    Apr 29, 2002
    946
    +24
    Just bought a Philips 890(?o-dear?)
    Seems to jump about chapters, will it settle or shoul I wave goodbye.MR playing R1 5th element
    Ged
  2. alan8477
    alan8477
    Dec 17, 2001
    593
    Pershore
    +11
    There have been many problems reported with the older Philips 985 machines on the http://dvdplusrw.org site. The 880 and 890 machines have been much less problematic. I have looked on that forum and cannot see any obvious similar problems but you may like to check yourself. I bought an 890 in November and it has been extremely reliable, after some early user errors that is.
    I rarely use mine for pre-recorded DVDs and therefore have never put it to your sort of test.
  3. Ged
    Ged
    Apr 29, 2002
    946
    +24
    Thanks, it looked like the fault was a "blob" on the disc, seemed ok later. Strangely the pre film warnings are not FBI but Asian, yet do show FBI on my Sony 900v MR - very strange!
    Ged.
