8800GTS on my system?
ignorancez
I am thinking about getting the "BFG Tech® GeForce ® 8800 GTS OC 320MBPCI Express Graphics Card Intl" sold on amazon. Im pretty sure that this will work on my system but to be sure I want to check with the pros :p
My Specs:
AMD Athlon 64 X2 4200+ (E6) (939 skt)
Gigabyte K8N-SLI Motherboard
2GB DDR400 Memory
500W PSU
nobla
Hello mate,
Ive got the same motherboard and CPU as you. 8800GTS should fit in there nicely. Im currently running a 7900GT but gonna upgrade to an 8800GTS when theres a game worth the upgrade
Regards,
Anthony
SeanT
Hey, it's overkill, but it'll work great!! (as long as you don't have a very rare AGP 939 board)
Synchro
I think he means its a high spec card. If you want a high spec card (there are higher spec cards than this though), then thats fine.
ignorancez
hahaha. yeh. this is perfect for me. dont wont anything higher. I know this might be a silly question. whats the best game that this gpu can take? All of it :rolleyes:
