icequake2000
could anyone tell me if the 8800gts 320mb is good enough for all games at max settings with 1680x1080res or lower.
8800gts works better at higher resolutions then your running all tests show this and anything over 70 is fine.
I wonder if anyone can help me out this problem is driving me crazy got 8800 hooked up to DTL-632V200 dvi to hdmi but it wont set to 1360x768 only it keeps going so the desktop is way to big for the screen never had this problem with ati 1950 it's this bloody nvidia card.
thanks for the help i think i will go for the 640mb. just wondering would the 640mb run the ultra setting in doom? or would you have to get the gtx for that.
Doom 3? 8800?You can run Ultra settings on a 6600GT iirc!!!
You do NOT need an 8800 for Doom. At all. Currently the only game which gives the 8800s something to chew on is Stalker.
The 6600gt has only got 128mb of memory i though you had to have a 500mb card to run doom ultra. so would that mean that the 320mb 8800gts would run it as well or would you have to have a 640mb card.
Uncheck the box "Hide Modes Not Supported" then try.
If the TV says "Mode Not Accepted" then just wait 15s and it will revert to what it was![]()
