868i OR Denon 2200 + Scaler
Discussion in 'Blu-ray & DVD Players & Recorders' started by Ajax, May 20, 2004.
  1. Ajax
    Ajax
    Feb 4, 2004
    170
    Hello,
    As per the title which would give the best results for a Panasonic AE500?
    A Pioneer 868i via HDMI>DVI,
    OR
    My Denon 2200 > *A Scaler of some sort*>DVI
    Help?
    Ajax.
  2. buns
    buns
    Apr 29, 2001
    6,100
    58
    Belfast
    the later option would be my choice. It offers so much more room for adjustment and expansion that it seems to me a no brainer
    ad
  3. Ajax
    Ajax
    Feb 4, 2004
    170
    Cheers Buns,
    I hoped that would be the case. If i told my wife that i was replacing a 2.5 month old DVD player she would do unspeakable things to me. Saying that telling her that I want to spend another £800 or so will probably yeild the same results!!
    Do you have any suggestions for a scaler. I have brought this up before but I still need convincing.
    Cheers again.
    Ajax.
  4. gizlaroc
    gizlaroc
    Jul 26, 2001
    9,515
    Norwich
    +981
    I would go for one of the lumagen units, with dvi, and I would put sdi on it as well, you can always upgrade the dvd or add sdi to sky at a later date.
    Have a look on www.lumagen.com for more info.
  5. buns
    buns
    Apr 29, 2001
    6,100
    58
    Belfast
    I would suggest the lumagen visiondvi.... it isnt released yet but I think will do within the next couple of months at worst. It would be £800 and is meant to be doing almost anything you might want.
    The sdi option gizlaroc suggests is a good plan but I guess would take you over budget. In reality it doesnt matter unless you have immediate plans with sdi since you can always get the sdi option added later
    ad
  6. Ajax
    Ajax
    Feb 4, 2004
    170
    Hello,
    I had identified the Lumagen DVI as the one that I could afford. However I have heard that the DVI only supports fixed resolutions and refresh rates. Would this be a big issue? The HDP is £400 more and my wife has already stated her immense displeasure :nono: at me spending £800. If it offers more flexibility and significantly better performance would it be worth the earache?
    Ajax.
  7. buns
    buns
    Apr 29, 2001
    6,100
    58
    Belfast
    no one has seen both units (the HDP is on very limited release and the dvi isnt out for a while yet) so impossible to say whether the HDP would be worth the extra for you. Gordon would be the man to talk to about it though and im sure will know as much as anyone wrt fixed resolutions and rates.
    all the best
    ad
