868 and 434 vertical lines
Discussion in 'Blu-ray & DVD Players & Recorders' started by Graham Sims, Nov 30, 2003.
  1. Graham Sims
    Graham Sims
    Sep 30, 2001
    68
    Lincoln
    This evening I was playing some pal dvds in progressive scan mode from a pioneer 868 dvd into a pioneer 434 plasma, I noticed when the brightness is turned right up, I could see vertical black lines in the picture. This is more noticable on dark scenes. They are stationary.
    It only happens in pal progressive scan mode, if I switch to interlaced, they vanish. They are also not there in ntsc progressive scan.
    If i turn the brightness down to normal levels they are less noticable.
    Has anyone noticed similar with this player?
    Cheers,
    Graham
  2. figrin_dan
    figrin_dan
    Jan 9, 2003
    2,045
    +155
    Possibly No help at all but My Pioneer CLD1450 laserdisc player shows these lines on PAL discs (they travel upwards and are very hard to spot) I was told it was due to a bad power supply.
  3. Billilu
    Billilu
    Call me crazy, but I think the answer might be not to turn your brightness right up.
    That's what I call looking for faults.
  4. Graham Sims
    Graham Sims
    Sep 30, 2001
    68
    Lincoln
    Billilu
    I see you have the same plasma and dvd, do you get the lines in progressive mode.
    I know its not a problem as you can't see them when the brightness is turned down to normal levels, but I was wondering why they are there.
    Cheers,
    Graham
