856*480 converts to 848*480 on pj
Discussion in 'Desktop & Laptop Computers Forum' started by cameronl, Sep 7, 2005.
  1. cameronl
    cameronl
    Aug 13, 2002
    1,146
    38
    +11
    hi there all, i recently upgraded my 9800 to a 6800 GT.
    On my 9800 I used to be able to go
    848*480 @ 60 hz to my sim2
    when i try this on my 6800 GT it doesn't work. If i set my 6800 GT to
    856*480 @ 60 hz to my sim2 I get the proper 848*480 displayed on pixel by pxiel setting.
    My question is....am I actually loosing 8 pixels of width here or is it acutally sending 848*480 to my pj? Everything looks ok to me :)
    CaM
  2. Mr.D
    Mr.D
    Jul 14, 2000
    11,064
    +1,149
    Look at the desktop see if its shaving pixels of either side ( hopefully it will otherwsie its scaling). My plasma is 852x480 but works best at 856x480 with a couple of pixels lost either side
  3. cameronl
    cameronl
    Aug 13, 2002
    1,146
    38
    +11
    ok, will do. I had a quick check when i did it and it looked ok - but pixels are pretty small!
    it's kinda annoying that it worked fine on my old ati card though.
    i guess it is time i played with the advanced timings....
    CaM
  4. TopMeTom
    TopMeTom
    Sep 8, 2002
    8,228
    +261
    Hi Cam,
    Could you pass on your settings as I am trying to get the best piccy on my 200dm through my pc?
    I currently have a 6200tc card wondering if I need to upgrade?I have theatertek just watcehd chronicles of riddick on the plasma noticed a few bits of picture flick,not enough to put you off,I notice 'em though.
    Cheers,
    Phil
  5. CyBeRkId2002
    CyBeRkId2002
    Mar 9, 2004
    2,584
    83
    +124
    i think the problem your having is to do with the EDID information gained from the projector. Nvidia cards adhere to this information more strictly than ati and as such I have just switched back from a 6200 to a radeon 9250se.
  6. cameronl
    cameronl
    Aug 13, 2002
    1,146
    38
    +11
    hi there, on my older 9800 I could get 848*480@60 working fine. With powerstrip I can also get it working fine.
    On my 6800GT through nvidia console I can't get 840*484@60 working that great. I can get 848*480@61 working fine and 848@480@50 working - though not when watching movies via theatertek :(
    If you download powerstrip and use the default 848*480@60 it will work fine. Once I get 848*480@50 working everytime I'll post it. When runing at 60hz it seems fine though.
    let me know how you get on. :)
    CaM
  7. TopMeTom
    TopMeTom
    Sep 8, 2002
    8,228
    +261
    Why not through theatertek?
    I only have two days left before they take me money....
  8. cameronl
    cameronl
    Aug 13, 2002
    1,146
    38
    +11
    I'm not sure why yet - maybe it is nvidia related. In any case theatertek works fine through 60hz as long as I'm in VR9 Fullscreen. I'm sure I just need a few more weeks worth of tweaking. :)
    CaM
  9. TopMeTom
    TopMeTom
    Sep 8, 2002
    8,228
    +261
    After doing some reading I am unsure if what i experienced was tearing?
  10. TopMeTom
    TopMeTom
    Sep 8, 2002
    8,228
    +261
    as a side note just run TT with ffdshow at 848x480@60hz was not that impressed.
    Tried 800x600 without ffdshow(i.e. the post processing option disabled in TT) looked a lot better?
  11. Mr.D
    Mr.D
    Jul 14, 2000
    11,064
    +1,149
    If ffdshow is setup properly you are not going to see a huge difference at that resolution anyway.
  12. cameronl
    cameronl
    Aug 13, 2002
    1,146
    38
    +11
    I now have it working at 50hz :)
    persist, persist, persist and then get lucky!
    CaM
