Bergggg
So a few years ago I posted up here when I purchased my 1987 Jamo dynamic D5e speakers. They where quickly repaired (rotted suspension) cleaned and put into action with an old stereo amplifier. I have been very happy with the sound quality and overall performance for the last 3 years, but despite the recommendations to rebuild the crossovers it just hasn't ended up being done and its time to do it.
Hoping for some help with this now, I had a lot of information off a couple of members back then and i have re-read through it all and want to go through and make sure I get it right more than anything, and possibly get more info.
Would it be wise/possible to make myself brand new ones from scratch? Replace like for like on the originals or upgrade components a better option?
As it stands going back through the old thread the only parts needing replacement are the capacitors and if the advice is still the same then so be it, I will post pictures through the process and maybe it will help others doing the same/make sure it's done correctly and give people something to read if they are interested.
I also could do with recommendations for an amp that will work well with these speakers as the one i'm using at the moment has no remote and the volume control has been broken by excitable children I think it's been forced past the stop.
