806 picture problem (not blue dots for once)
Discussion in 'AV Receivers & Amplifiers' started by Tommy Kaira, Nov 27, 2010.
  1. Tommy Kaira
    Tommy Kaira
    Dec 12, 2008
    55
    11
    +3
    Hi guys.
    I wonder if anyone can help. When I play a game/DVD/Bluray on my PS3 through my Onkyo TX-SR806 any graduated colour shows up as bands of colour instead of a smooth transition. See the attached picture and it'll make more sense.
    [​IMG]
    I've tried different TVs/projectors and different sources (direct through the TV works fine). So I'm fairly sure the problem is with, you've guessed it, the Onkyo!
    The problem hasn't always been there. I started to notice it after I moved the system around. (It's been away for the blue dot fix if that makes a difference.) Are there any settings that might have been changed accidentally that i can try before I throw it through Sevenoaks' shop window?
    Any help would be much appreciated.
    TK
