8002880C error playing back avi's
Discussion in 'Playstation Forums' started by TheBiggestLie, Jan 18, 2008.
  1. TheBiggestLie
    TheBiggestLie
    Sep 20, 2007
    120
    +5
    Hi all, did a search and surprised I didn't find anything.
    I'm trying to play back an episode of Simpsons I missed and just after the intro I get a 8002880C error! If I retry and skip that point it carries on playing. I've tried playing this through WMP11 and off a USB stick and it seems that it's the AVI that's the problem. It also happens with a couple of other avi's I've tried playing.
    Has anyone else had this issue? I'm guessing it's due to the way it was encoded, but then I wouldn't have expected any of the avi to play at all. The same file plays fine through the Xbox and PC. I'm guessing this is a Sony firmware issue that they could fix if they were bothered.
  2. branny
    branny
    Feb 26, 2005
    3,693
    103
    Pie Land
    +274
  3. TheBiggestLie
    TheBiggestLie
    Sep 20, 2007
    120
    +5
    Cheers. Yeah, I did have a look and it seemed to be an issue with the way the avi was coded. I didn't find anything too substantial though. Kind of a bummer for me because I mainly use the PS3 as a media centre, but now with at least two avi's not supported via this error (as well as the ones that don't play back at all), I'm wondering if I should make the Xbox my main media centre.
  4. Dragy2k
    Dragy2k
    Jan 22, 2007
    518
    bristol
    +38
    hi cant you just recode the bad avi file in question ???
  5. TheBiggestLie
    TheBiggestLie
    Sep 20, 2007
    120
    +5
    Yeah, it's not a major problem, I just don't want to do it every time. In fact I normally just turn on the Xbox 360 and use that instead, I was just curious how much of a problem it was and hoping that Sony would fix it in a later firmware release.
  6. dmx0007
    dmx0007
    Feb 8, 2008
    216
    im having the same problem i think its to do with the Playstation update because i have a lot music videos on my PS3 and they were working fine till i updated it to 2.20 and them music videos bring up the error in question when i watch them.
    does any one no if Sony will be fixing this problem.and can any one recommend a program to convert movies to watch them on the PS3?
    thnx
  7. GhostDog1
    GhostDog1
    Feb 25, 2008
    5
    yea im getting the same thing, and it seems like its gotten even worse with 2.3, anybody got a sulution to this ? really anoying :thumbsdow
    sure hope Sony does something about this
  8. Pincho Paxton
    Pincho Paxton
    Oct 3, 2006
    14,128
    +635
    I think that Sony are trying to stop people playing certain copies, maybe? That's why I never update my PS3. Mine is Version 2.0. Luckily I never use it online.
  9. dmx0007
    dmx0007
    Feb 8, 2008
    216
    i don't think Sony are trying to stop us from playing copies because other wise they wouldn't give a update where we can play back Divx and AVi format videos.i think they rushing in updating it and messing up other parts of the playstation.
  10. Zeromajor
    Zeromajor
    Feb 9, 2008
    4,419
    Btown
    +594
    Taking out a feature is a concious decision - they're not just knocking something out by accident.
    This is where homebrew needs to step in imo.
  11. dmx0007
    dmx0007
    Feb 8, 2008
    216
    yeah i no mate I'm just saying they are making BIG mistakes when they do a update on the console.
  12. TheBiggestLie
    TheBiggestLie
    Sep 20, 2007
    120
    +5
    Wow! I don't check for a while and when I do, my threads back on the first page again :D
    Um, not really noticed this issue recently. And that's saying something considering I swapped in a 320gb HDD and have all my media files stored on the PS3. I've not seen the particular 8002880C in a while, but have had to recode certain files as it was easy to tell from the play list whether the file was supported or not (avi thumnail not visible).
    For the earlier poster, I use either VirtualDub or SUPER to convert. VirtualDub is pretty powerful, but SUPER is great for batch conversions.
  13. dmx0007
    dmx0007
    Feb 8, 2008
    216
    where can i get SUPER from? is that the full name of the program just SUPER?
  14. GhostDog1
    GhostDog1
    Feb 25, 2008
    5
    thx TheBiggestLie :D just re encoded one of the said files with SUPER and the problems gone, I had to play around for a while with the setting though to avoid loosing picture quality :)
    still though, I sure hope sony sorts this out, its pritty sad that the ps3 cant handle a little glitch in a divx file without crapping out, hell the xbox360 playes right threw huge glitches like a PC would. (not that I even own a xbox)
    Direct Download Link:
    http://www.erightsoft.info/GetFile.php?SUPERsetup.exe
    Info About Super from the creators:
    http://www.erightsoft.com/SUPER.html
  15. TheBiggestLie
    TheBiggestLie
    Sep 20, 2007
    120
    +5
    No problem. If you double click on the file, SUPER gives you the information about the file. You can then just select the nearest bitrate and audio settings to match to give you the equivalent quality!
  16. GhostDog1
    GhostDog1
    Feb 25, 2008
    5
    yea tried that, and lost alote of quality, so I had to sett the bitrate up to double size for some reason, but whatever :p got plenty of space :)
