8 speaker terminals on the back of a Cyrus X Power??
roystonchris
Long time no post (although I do get to read occasionally).
Just acquired a 2nd hand one of these to link between my AVR and PMCs as the previous power amp died.
I don’t get it though, there are 4 speaker terminals on each side. So (assuming single wiring of speakers), which do I use? The top pair on each side, or the bottom? What’s the difference?
NB: the manual is happy to describe bi-wiring (which, yes, I know my PMCs do technically support) and bi-amping, but doesn’t say for single. The former power amp only had 4 terminals, so single-wiring was only ever the option.
Can't try out yet, as just found out I need to buy some different (sigh) speaker connectors for the Cyrus.
Thanks!
barnitto
I don’t believe it matters which you use, I would just use the top pair on each side.
larkone
It's in the manual P6
Dual outputs are provided for the convenient connection of bi-wiring speaker cables.
