8' away from 42" plasma......... TOO CLOSE ?
Discussion in 'Plasma TVs Forum' started by Daipac, Jun 8, 2005.
  1. Daipac
    Daipac
    Apr 12, 2005
    659
    +12
    When I do make the plunge (AGAIN) and get a plasma, I am planning to mount it in my living room.
    After measuring up last night, it will be sitting around 8' away from my settee.
    My question is, is this too close ?
    I know it is far from ideal but will it cause problems ?
    If it will, I will have to seriously rethink what size I am going to go for.
    :suicide:
  2. Jazz Monkey Jr
    Jazz Monkey Jr
    Jan 10, 2005
    14,242
    2
    4
    137
    Garstang, Lancs
    +1,625
    I think 10 feet is ideal - and that is for a SD panel, if you are getting to PV500 you can get away with sitting a bit closer because of the smaller pixels.
    You should be fine..don't get any smaller.
  3. codlord
    codlord
    May 17, 2002
    283
    Portsmouth, UK
    My plasma is about 6' from the front of my sofa which means my head is about 8' away and it's absolutely fine. This was one thing I was worried about before I got mine cos my room is so narrow but no problems at all.
  4. xenole
    xenole
    Jan 2, 2005
    117
    From my seating postion to where the plasma is going to go is about 10-10.5ft.
  5. Daipac
    Daipac
    Apr 12, 2005
    659
    +12
    That is the problem with my living room, it is around 10'-12' foot wide and about 20' long but the chimney breast comes into the room so where I want to mount it is around 8' away.
    I sit the same distance away from my current 32" Sony Wega and that is not a problem.
  6. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    I think it could depend on the resolution of the screen. I sit about 8' away from my Hitachi 42" plasma - that's a 1024 x 1024 screen, and have no problems. I recently was looking at a friend's 852 x 480 screen from the same distance, and it looked distinctly "pixelly".
  7. TeresaTT
    TeresaTT
    Sep 11, 2004
    508
    Walsall
    +13
    I sit about 8' away from my PWD6 and don't have any problems with the distance. DVDs look stunning and Telewest digital cable TV is watchable although some of the more compressed channels look poor, but then they'd probably look bad even from a larger distance. My young son finds a viewing distance of 2' to 3' just perfect for CBeebies.
  8. k0rn
    k0rn
    Besides the pixel issue, it´s also a question if your eyes can handle it on this short distance. I think with only 8feet it can be too much for some people..
    I have about 8 feet distance myself and I went for the 37"... currently have a 32" CRT and I think at some point the picture gets too big for the eye to capture it. (without having to move the head constantly like in the cinema if you sit in the front row)
  9. Enquirer
    Enquirer
  10. BIGMAX
    BIGMAX
    Jan 11, 2005
    746
    +18
    I was wondering the same, as I sit about 9 feet away from a 43 inch. But now I reckon the 50 " would have been fine. But I suppose it depends on the individual.
  11. TeresaTT
    TeresaTT
    Sep 11, 2004
    508
    Walsall
    +13
    My next screen is going to be 50" if I can afford it. A 42" screen is still too small for 2.35:1 movies at a distance of 8'.
