Quantcast
7mc (MediaBrowser) only plays a movie on 2nd attempt
icstm
Sorry for starting a new thread, but could not find a relavent live thread on 7mc or mediabrowser.
I have an odd problem, mediabrowser shows an error the first time you try to play a file (it says something like "cannot play this file" or "can't render file"). The error looks like a 7mc error, as it comes up with the 7mc skin.
If you try again (ie go back to the library and select the same movie/tv show) it works.
1) I am using ffdshow
2) error does not occur direct from 7mc library
Anyone else have this 2nd time lucky problem? It seems pretty standard.
icstm
mpc's splitter
MKV (264, not vc1)
The error is
cannot play Video
WMC cannot open the file
It then must change focus windows, as normally your mouse is fixed to the screen using 7mc, this stops being the case.
So you click back on the maximised 7mc. You click back (as the screen is just blue with the video controls at the bottom) and then select the movie or hd tv show again and the screen flickers and then plays.
Once you have done this (or played an avi file first) it will play mkvs no problem rather the remainder of the session.
Does not appear to affect the main 7mc in the same way.
wolvers
Did you check for the ffdshow icons in the notification area of the taskbar when your videos are playing? You'll need to have 7MC windowed to see it.
icstm
no need, as I run 7mc on the TV, with the primary desktop still on the monitor.
The error occurs before FFDshow is called.
icstm
Any thoughts? :rolleyes:
Only occurs on first mkv launch within 7mc, no problems with WMP.
AVI files play fine first time, as do actual DVD isos.
Only clue, the screen flickers first.
wolvers
Or it occurs trying to connect to ffdshow. Try checking the registration of ffdshow with the filter tweaker, deselect it, save then select and save again. Possibly try reinstalling or updating the version of ffdshow?
icstm
OK, will give this a go tmr evening
EDIT, However I just tried removing FFDShow, and just using the MPC matroska splitter. In other words, using the built in MS filters to handle h264 and DD sound.
That too gives an error on first run :(
icstm
btw, could it be linked to THIS issue?
I resolve the playback thing, I have unregistered the other MPC filters, only leaving the mkv one for now.
Similar threads
