7m+ optical lead
Discussion in 'Cables & Switches' started by gingerone, Apr 28, 2005.
  1. gingerone
    gingerone
    Dec 10, 2002
    2,567
    +388
    Hi I need a 7m+ optical lead as I'm moving my dvd player due to a new projector.
    Any ideas for a decent cable at a decent price( under £80).
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,746
    The Borders
    +3,085
    gingerone
    VanDamme supply a 10m Toslink Optical cable for well below £80.00.
    We use and supply a lot of the shorter ones and have never had any issues with the longer ones we've supplied.
    Best regards
    Joe
    PS Check out the Banner adds - there may be alternatives.
  3. gingerone
    gingerone
    Dec 10, 2002
    2,567
    +388
    Cheers for that I'll track one down.
  4. stewd
    stewd
    What would be the maximum length an optical cable could be extended to?
  5. CJROSS
    CJROSS
    Nov 16, 2000
    5,102
    +343
  6. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,746
    The Borders
    +3,085
  7. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
    Well manufactured optical fibres can propagate light hundreds if not thousands of kilometres with very little trouble. Photonic crystal fibres aren't widely available yet but have even better properties.
    The problem in home cinema is that the cable connectors (usually Toslink) aren't great so it's worth spending a bit to make sure that the connection and lens are of good quality. The other limiting factor is that LEDs are used to produce the light which is sent down the cables, the dispersion characteristics of LED light down optical fibres aren't great so really you're limited to a few tens of metres in the HC environment. :)
