7ft Walter Stewart Screen Horizontal Ripples
Discussion in 'Projectors, Screens & Video Processors' started by obiwan, Jan 6, 2003.
  1. obiwan
    obiwan
    Nov 22, 2002
    319
    Devon
    +5
    I have this screen, 80x45". Only a few weeks old.
    The first time I pulled it down I did not notice any marks or ripples on it, thats not to say they may have been there.
    But now every time I pull it down there are ripples approx. every 6". They tend to go when the screen is left down long enough.
    Is this a duff screen, or a a good/bad way to put it back up??
  2. richard plumb
    richard plumb
    Jan 27, 2002
    14,340
    Windsor
    +1,026
    I noticed a few ripples in my Draper luma (same size as yours) after only a few uses. I left mine down overnight (mainly because it smelled bad) and they went. So I'll do that whenever I get ripples in the future.
  3. Gordon @ Convergent AV
    Jul 13, 2000
    13,982
    +2,786
    Have you made your supplier aware of this? Sounds like you are seeing where the screen material is rolling over itself where it is attached to the drum. This is more common on other manufacturers screens. I've never seen it on a Luxus ModelA
    Gordon
  4. Turl
    Turl
    Richard,
    I had the same problem with my 7ft Draper screen which was promptly replaced by the supplier. However the same problem exists with the replacement so I assume this is a general design problem for some manufacturers. The screen material is definately rolling over the bonded strip on the roll and causing the screen material to stretch about every 5 to 6".
    I'm now looking for a good deal on a 7ft tab tensioned screen!
    Turl
