wack
I bought a samsung UE75JU6400KXXU from costco in 2016 , its developed a vertical banding problem which has been highlighted by the recent purchase of a 4k Xbox
Costco have decided to write it off and have offered a refund of the £1400 + vat I paid for it , this gives me £1700 to play with which I could increase to £2500 without attracting too much attention
I'm baffled by the number of TVs in this price range so any advice is appreciated, I'm used to 75" now so wouldn't really want to drop 10" but I do like a bargain so if one was about on a high end older model I might consider it
Please answer the following questions:
Will you be buying and using an UHD Blu-Ray player? no
Netflix? YES
Amazon? YES
Apple TV NO
Catch up TV? YES
HDR games consoles? YES
PC usage? NO
DVDs? yes
FHD Blu-Rays? YES
Sky, BT or Virgin? UHD or HD? HD
Please rearrange the following PQ attributes, in descending importance:
Blacks
How accurate the picture is out of the box (without having to change any settings)
SDR Brightness
SDR Colour Saturation
SDR Colour Accuracy
HDR Brightness
HDR Colour Accuracy
HDR Colour Saturation
Local dimming
Now for bugs, tell us your possible pet hates related to TVs, in descending order:
Bad screen uniformity, Dirty Screen Effect, Clouding, Light Bleed, Blooming
Temporary image retention
Loss of detail in dark areas
Reflective screens
Haloing
Motion Blur
Motion Judder
Motion stutter
Soap Opera Effect
3:2 Pulldown Judder with 24hz movies. See: Judder-Free 24p on TVs
Now which is most important to you?
Price
SDR PQ
Sound
Smart TV (which apps)? Netflix Amazon Prime
HDR PQ
Connections
Wide Viewing angles
- What are your sources going to be? For example:
Netflix? YES
Amazon? YES
Apple TV NO
Catch up TV? YES
PC usage? NO
DVDs? yes
FHD Blu-Rays? YES
- SD vs HD vs UHD use percentage? 0% 80% 20%
- Movies, sport, console games, PC use in percentage? eg 80% 0% 10% 0%
- How close can you view the TV? 10-12FT
- Do you need to view the TV from the side or only straight on? STRAIGHT ON
- What conditions do you view in? During the day? At night with lights on? In the dark? DAY & NIGHT WITH DIM LIGHTING
- What TV are you currently using and what are expecting to see upgrading to a new TV?samsung UE75JU6400KXXU Happy with the HD picture on this TV so anything better is a bonus
- Motion - Are you interested in being able to use motion enhancements on your TV to reduce judder and/or reduce motion blur? Both frame interpolation and frame insertion let you do this, read more about it here. They both have their upsides and downsides, so read carefully. No
Blacks
SDR Brightness
SDR Colour Accuracy
HDR Brightness
HDR Colour Accuracy
Local dimming
Reflective screens
Haloing
Motion Blur
Motion Judder
Motion stutter
Soap Opera Effect
Price
SDR PQ
Sound
HDR PQ
Connections
Wide Viewing angles
