75 Hz on Pio 434 ?
Discussion in 'Plasma TVs Forum' started by joys_R_us, Nov 29, 2003.
  1. joys_R_us
    joys_R_us
    Joe Fernand distributed a leaflet which shows that Pio 434 does 72 Hz on NTSC and 75 Hz upsampling on PAL.
    I assume that this is the ADV option which is deactivated on my Pio 434 for PAL.
    Anybody with more knowhow ?
    Joe ?
  2. Costas
    Costas
    Jan 14, 2003
    1,663
    63
    Swindon, UK
    +120
    The ADV option on PureCinema can only be selected for NTSC signal. See page 37 of the operating instructions manual.
  3. SimonO
    SimonO
    Nov 4, 2002
    3,293
    71
    Hertfordshire
    +64
    STD for PAL 2:2 pulldown, ADV for NTSC 3:2...
  4. joys_R_us
    joys_R_us
    I know what is in the manual.
    I was referring to this leaflet:
    (remove the .txt at the end to watch the pdf.file)
  5. SimonO
    SimonO
    Nov 4, 2002
    3,293
    71
    Hertfordshire
    +64
    Can't put it much clearer... :smoke:
  6. joys_R_us
    joys_R_us
    I understand 75 Hz as 3:3 and not 2:2
  7. SimonO
    SimonO
    Nov 4, 2002
    3,293
    71
    Hertfordshire
    +64
    Ok yes you are right, the circuit will take the 25fps and effectively show each frame 3 times... On the 434 this is the STD PureCinema mode...
    [Obviously this is only for film flagged material]
