737 picture problems !
Discussion in 'Blu-ray & DVD Players & Recorders' started by MW, Mar 13, 2001.
  1. MW
    MW
    Im having some problems with my Pioneer 737. Ill do my best to describe. If there is a light object on a darker back round ( or vica versa)a subtle horizontal band can be seen across the entire screen the width of the object distorting the color. (Eg. a white credit on black back round has a whitish band across screen) . Its mostly subtle and not noticeable, but in scenes with lots of dark and light contrast it quite prevalent. It only occurs in RGB output mode, I have Straightwire scart-scart lead, into a very cheap Samsung TV with RGB scart. My initial thought are its the TV. Im moving back to Oz soon so I dont want to buy a better TV. Has anyone come across this effect, or have any thoughts on the cause?
    Cheers!
  2. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,619
    Somewhere in South Yorkshire
    +6,170
    My first suspicion would fall on the TV. I use my 737 in S-video, Composite, and Component and have never seen what you describe. But shadowing like this is prevalent on cheap CRTs - you even see it on some early computer monitors.
    Can you check this against other sources (eg digital satellite or on-digital) to see if it is the same? Can you also check other outputs from the DVD into the same TV - eg composite or S-video? This might narrow it down.
  3. Arthur.S
    Arthur.S
    Can you turn off the comb filter on the TV?
    www.baldyplex.com
